To save the configuration database, use the save command. Enter:
CM Edit> save Filename (CONSOLE$DATA:CONSOLE_CFG.DAT):
Alternatively, you can save your configuration database by leaving the editor using the exit command. This automatically verifies the data and writes out the database file.
Copyright © 2010 CA.
