Previous Topic: Deleting From the Configuration DatabaseNext Topic: Saving the Configuration Database
Verifying the Contents of the Configuration Database
When you have finished modifying the configuration database you can verify that the data you have changed is valid. To do so, use the verify command. For example:
CM Edit> verify
Verified successfully
If you have entered any inappropriate information, you receive a verification warning message.
