Timeout is the period ENS waits for an action routine to connect to it and request events. If an action has been dispatched and does not communicate with ENS within this period, a new instance of the action is created. This only applies to the image type action routine. See the chapter Setting Up the ENS Components for more information about image routines.
To set timeout for action routines, enter:
CM Edit> set timeout Action routine timeout seconds (60): 30
To keep the default value, press Enter. To set your own value, enter the number of seconds you require.
In this example, the default is being changed to 30 seconds.
Copyright © 2010 CA.
