The root or system account (depending on the operating system you are using) has all the Console Manager privileges by default. You cannot change this information as there is no entry in the configuration database for this account. If you do create an entry for user root or system, Console Manager will ignore it, and use the default.
Unless a user has an entry in the configuration database, they are not allowed to perform any of the Console Manager functions.
Note: It is important to realize that granting a user privileges to edit the configuration database allows that user to set all other privileges for both themselves and any other user.
Note the following rule regarding usernames:
Console Manager automatically uppercases the username when a user starts the various interfaces in order to check for a match against the user authorization file entry.
You will need to create security profiles if any of the following apply to your configuration:
To define a security profile, use the Add Security_Profile command.
To add a security profile
CM Edit> add security_profile
Security profile name: JSMITHsecure
Information: John Smith, System Manager
Username (): SMITHJ
Password ():
Passphrase ():
For more information about this logical name see the chapter "Set up the Environment".
OK to add? [Y/N (Y)):
Copyright © 2010 CA.
