To give users access to serviced systems and grant them Console Manager privileges, use the add user command. This displays a series of questions about which privileges should be granted, along with a list of systems and/or groups of systems the user is going to be allowed access to.
You can press Enter to accept the default. However, this results in a user having no privileges or access.
The username given must match the user's account name.
CM Edit> add user
User Name: smithj
Information: John Smith, System Management
Can user perform startup from the C3 interface? [Y/N] (N): Can user perform reconfigure? [Y/N] (N): Can user perform shutdown? [Y/N] (Y): Can user edit database? [Y/N] (N): Can user unlock consoles? [Y/N] (N): Can user halt the system? [Y/N] (N): Can user perform archive? [Y/N] (Y): Can user exit C3? [Y/N] (N): Can user edit C3? [Y/N] (N):
Can user access all systems? [Y/N] (N):
Note: If you grant access to a subset of the serviced systems defined in the configuration database, then a group definition is also required. However, granting a user access to all groups overrides the subset of systems, and provides the user with full access.
Can user access all groups? [Y/N] (N):
OK to add? [Y/N (Y)):
The following is an example of what you see on your screen:
Database contains NO verification errors CM Edit> add user User Name: smithj Information: John Smith, System Management Can user perform startup from the C3 interface? [Y/N] (N): Can user perform reconfigure? [Y/N] (N): Can user perform shutdown? [Y/N] (Y): Can user edit database? [Y/N] (N): Can user unlock consoles? [Y/N] (N): Can user halt the system? [Y/N] (N): Can user perform archive? [Y/N] (Y): Can user exit C3? [Y/N] (N): Can user edit C3? [Y/N] (N): Can user access all systems? [Y/N] (N): Can user access all groups? [Y/N] (N):
Copyright © 2010 CA.
