A group is a subset of the defined systems in the Console Manager configuration database. For example, the New York group consists of all systems in the New York branch office. A system can be a member of multiple groups.
To add groups to your configuration database, use the add group command
CM Edit> add group
Group name: New York
Information: All New York Systems
Are all systems members of the group? [Y/N] (Y): n
Enter the systems which are members of this group (?=list) System (CR=end): pepper System (CR=end): salt System (CR=end):
OK to add? [Y/N] (Y): y
The following is an example of what you see on your screen:
Database contains NO verification errors
CM Edit> add group Group name: New York Information: All New York Systems Are all systems members of the group? [Y/N] (Y): n Enter the systems which are members of this group (?=list) System (CR=end): pepper System (CR=end): salt System (CR=end):
Copyright © 2010 CA.
