The following table lists the commands that are available in the configuration editor.
Command |
Arguments |
add |
action, event, scan, system, user, filter, group, security profile |
modify |
delete |
set |
archive, filespace, timeout |
show |
actions, archive, events, filespace, summary, systems, |
verify |
no arguments required |
use |
filename |
save |
filename |
import1 |
filename |
export |
filename |
exit |
quit |
help |
@2 |
filename |
1Import is synonymous with @ |
The arguments used in the table are case-insensitive.
See the chapters Understanding ENS through Create Your Own Action Routines for information about adding, modifying and deleting actions, events, scans and filters.
Copyright © 2010 CA.
