To display a list of the commands online, enter help or ? at the CM Edit> prompt.
For more information about a command, enter help followed by the command. For example,
CM Edit> help add
add, modify, or delete the following record types: action - Script or program to be run when filter criteria has been met. Specify action in filter record. event - Description of console text string to search for. filter - Defines what actions to take for specific events. scan - List of events and/or other scan definitions. system - Name of system having the console to monitor. group - Logical grouping of systems. user - Who can do what.
Copyright © 2010 CA.
