To start the configuration editor, enter:
$ CONSOLE EDIT/INTERFACE=CHARACTER_CELL
This takes you into the configuration editor, which informs you whether or not there are any verification errors (in this example, there are no verification errors):
CA Console Management Character Cell Editor version Vn.n-mmyy Copyright (c) 2001, 2004, 2009 CA. All Rights Reserved.
Database contains NO verification errors
CM Edit>
If there are any verification errors, then the following message is be displayed, where num_errors is the number of errors:
Database contains num_errors verification errors
To find out what the verification errors are, enter:
CM Edit> verify
Also, if another user is currently editing the configuration database, the following messages will be displayed, and you will only have read access to the database:
Database currently locked by another user No access to modify database, Read-Only mode enabled
Copyright © 2010 CA.
