Previous Topic: Steps for Setting up Console ManagerNext Topic: Hardware Requirements
Set up the Environment
Do not follow the instructions in this chapter until you have installed the Console Manager software on your host system. When you have installed it you are ready to follow the instructions in this chapter for connecting the host system to the serviced systems.
Note: If you are using VAX 8500/8700/8800 systems as serviced systems, you must complete additional setup tasks, which are explained in appendix A, “Using VAX 8500/8700/8800 Systems as Serviced Systems.”
This section contains the following topics:
Transport Types
Connect Using Direct Transport
Connect Using LAT Transport
Connect Using TELNET Transport
Connect Using Pseudo-terminals
Connect Using SSH Transport
Identifying and Solving Connection Problems
