Previous Topic: Set up a Direct ConnectionNext Topic: Configure for LAT
Connect Using LAT Transport
This connection consists of a host system connected to the same Ethernet network as the terminal or console servers used to connect to serviced systems. The serviced systems connect to the terminal or console server using DECconnect cables and adapters where necessary. Console Manager then uses host initiated LAT to connect to the terminal or console server. The following figure shows a LAT connection:
