Previous Topic: Splash ScreenNext Topic: Example: Add and Modify a Check Box Tree
Check Box Trees
A check box tree lists product components in a hierarchical structure. A sample check box tree is shown in the following screenshot:
Graphic showing a sample check box tree structure
When a component is selected, all sub-components are automatically selected. Required components are also selected, if the referring component is selected.
The component list can be parsed using a scroll bar.
Optionally you can define a text area that shows information about the selected component.
Two pairs of keywords let you define a check box tree control:
#tree_begin, #tree_end
A tree contains a list of check boxes.
#scrollarea_begin, #scrollarea_end
A scroll area contains a list of check box trees or check boxes.
