Using Packager and Installer for Linux and UNIX › Installation Dialogs › Check Box Trees › Example: Add and Modify a Check Box Tree
This example provides the information on how to add a check box tree to a selected installation dialog and then modify it.
This example covers the following topics:
- Add a check box tree
- Add a node to the existing check box tree
- Remove a node from the existing check box tree
To add a check box tree
- Select a package from the Project pane.
The general package options appear.
- Select the appropriate dialog from the Dialog tab (subproject pane).
- Drag and drop the check box tree icon from the toolbox to the desired location in the workbox.
- Click the check box tree icon in the workbox.
An empty area opens where you create and edit your check box tree.
- Right-click in this area and select Add Checkbox from the context menu.
The Input dialog appears.
- Enter the name of the check box and click OK.
The check box appears in the editing area; the name of the check box appears as descriptive text next to the check box.
To add a node to the check box tree
- Right-click the check box and select Add Child Checkbox from the context menu.
- Enter the name of the child check box and click OK.
The check box appears below the selected check box at one level down.
To remove a node from the check box tree
- Right-click the node in the check box tree.
The context menu options appear.
- Select Delete from the context menu.
The selected node is deleted from the tree.
