Previous Topic: Action ScriptsNext Topic: Check Box Trees
Splash Screen
A splash screen is typically presented at the beginning of an installation and pops up a graphic informing about the product, its version, and copyrights. The splash screen is shown in interactive installations prior to any dialog of the interview phase. When the interview is started, the splash screen disappears automatically.
You can specify a graphic in the GIF format, which is used as background graphic in the splash screen, and an optional text string that is displayed in the left bottom edge of the graphic, 10 pixels from each border.
In the prototype file, you use the keyword #splashscreen to define the splash screen; the text string is specified in the Resource section and can be localized. You can define line breaks in the splash screen text by using the tag <br> within the text string.
