Previous Topic: Dialog Validation ScriptsNext Topic: Splash Screen
Action Scripts
Action scripts can be defined for the use with check boxes, password fields, installation directories, file selection fields, combo boxes, and radio buttons. These scripts let you change attributes and contents of dialog elements (fields) in the installation dialog immediately, for example, to activate or deactivate fields.
You can find examples for action scripts under the directory $SDPcker/examples/advanced/actionscript, on the system where the Packager is installed.
