The Configuration Policy node in the DSM Explorer tree contains configuration parameter subnodes. Because the Configuration Policy node is dynamic, the Default Computer Policy, DSM node displays both common and plug-in specific nodes depending on what DSM-based applications or component plug-ins are installed.
The following configuration parameter subnodes, or folders, contain configuration policies:
* Indicates component-specific configuration policies.
Each corresponding pane contains the following fields:
Displays pane-specific tips for selecting options or entering information.
Displays the name for each policy.
Displays the value of each policy. A value may be a string, integer, or Boolean entry depending on the type of policy.
Displays the folder or property description for each policy group.
Note: When a computer policy is centrally managed, the value entered is propagated to all computers referencing the policy.
