The Administration Console policy group lets you view or edit the following policies for the DSM Explorer. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
The Administration Console policy group contains the following policies.
Specifies the wait time interval in seconds for the callback function.
Default: 1
Specifies the maximum number of objects that the DSM Explorer processes at a time.
Default: 3
Specifies the wait time interval in seconds for session messaging to return a result.
Default: 300
The SQL transaction isolation levels supported by DSM Reporter. The parameter is applicable only for Microsoft SQL server database. Select a value to configure the isolation level:
This option allows to generate the report, only after completion of database updates that are in progress. This reduces the report execution time.
This option allows to generate the report with the current snapshot, and avoids the database locks if any parallel database updates are in progress. This makes the report execution faster compared to Read Committed mode. The report uses the data snapshot when the report execution is started.
The Administration Console policy group also contains the following policy group folder:
Asset Management
