Previous Topic: Default Computer Policy (or User-Defined Policy) NodeNext Topic: Configuration Parameter Nodes
DSM Node
Upon installation a default policy with predefined settings is created under the Default Computer Policy, DSM node. This policy and its settings act as a template for any new policies you create. You can, however, change the default policy; if you do, any changes to the policy or its settings are also reflected in the new policies.
