Jobs Policy Group
The Jobs policy group permits an administrator to block the execution of asset management and software delivery jobs. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Note: Available categories and options may vary depending on the products and components installed.
Indicates whether asset management and software delivery jobs are disabled on the target agent. Valid values are True and False.
Note: If this policy is locally managed, then it can be changed on the target agent using the DSM Properties - Common Agent dialog, which is accessible from the system tray or by using the caf restrictjobs command. (For more information, type <command> /? at the command prompt.)
Default: False
