The Agent policy group lets you view or edit the existing policy properties for the common configuration agent. It contains the following policies:
Controls the behavior of the "caf register all" feature and the automatic agent registration that occurs when a network address change is detected. If True, all known units are registered. If False, only currently logged-on units are registered.
Default: False
Determines whether the host name is used for this agent. By default (True), the operating system name for the agent is used. If False, you can specify any name you want in the Agent Name field of the DSM Common Agent Properties dialog. This is useful to distinguish sets of computers that have the same OS name.
Note: For more information, see the DSM Common Agent Properties Help.
Default: True
The Agent policy group also contains the following subfolders:
Note: Available categories and options may vary depending on the products and components installed.
