The Asset Maintenance System (AMS) policy group lets you view or edit the following policy for AMS. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the URL for Asset Maintenance System (AMS) Web Services, for example, http://myhost/AMS/login.do. Replace myhost with the name of the web server that hosts AMS.
Default: <locally managed>
