Asset Management (Administration Console) Policy Group
The Asset Management policy group contains the following policy:
Specifies whether the RVI agent URL can be manually entered or edited in the virtual host inventory collect task. If the collect task is based on the host name, the RVI agent URL field is automatically populated in the collect task regardless of the value set for this policy
If True, the RVI agent URL field is enabled and you can edit the URL.
Note: If you make subsequent changes to the Host Name field, update the RVI agent URL field.
If False, you cannot edit the Web Service URL and the field is disabled.
Default: False, <locally managed>
