Asset Management Policy Group (Scalability Server)
The Asset Management policy group lets you view or edit the following Agent Bridge support policies for mobile PDA and legacy agents. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the wait time interval in seconds between subsequent runs of the AM Agent Bridge.
Default: 60
Enables Agent Bridge scalability server support for mobile and legacy agents, if set to True. If False, this policy disables Agent Bridge support for mobile and legacy agents.
This policy is set to False upon installation. If changed to True, then the AM Agent Bridge runs automatically upon startup. Note that until this policy is set to True, the AM Agent Bridge server cannot be started manually.
Note: Enabling AM Agent Bridge support does not mean that the SD Agent Bridge support is automatically enabled. For more information, see the Backwards compatibility support: Enable configuration policy in the Backwards Compatibility Support Policy Group topic.
Default: False
Enables the support of legacy user accounts in AM Agent Bridge, if set to True. If False, this policy disables AM Agent Bridge support for legacy user accounts.
Default: False
