Previous Topic: TCP Policy Group (Remote Control)Next Topic: Asset Collector Policy Group (Scalability Server)
Scalability Server Policy Group
The Scalability Server policy group lets you view or edit the existing policy properties for the common server. It contains the following policy:
Agent Trigger Method
Controls whether agent triggers should be sent using an IP address or a fully qualified domain name (FQDN) address. Typically, this method should be changed to FQDN in an extended network connectivity (ENC) environment. (For more information about ENC, see the Implementation Guide.)
Valid values are as follows: Trigger agents by IP address and Trigger agents by FQDN address.
Note: When a trigger is sent to an agent computer as a result of a pending job and the agent does not respond within the time limit (default 10 minutes), the subsequent triggers to the agent computer will toggle between the IP and FQDN methods.
Note: The AM server will need to be restarted for any changes to take effect.
Default: Trigger agents by IP address
The Scalability Server policy group also contains the following subfolders:
