Events Policy Group
The Events policy group controls the types of Asset Collector events that are tracked when event logging is enabled. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Note: For more information about event logging, see the DSM Explorer Help.
Specifies if an audit record is created for each successfully processed inventory file.
Specifies if an audit record is created when an inventory file is rejected because the collect time specified in the file appears to be a time in the future.
Specifies if an audit record is created when an inventory file is rejected because the collect time in the inventory file is older than a previous submission for the same asset.
Specifies if an audit record is created when an inventory file is rejected because its collection time falls within the same day window of a previously processed asset.
Specifies if an audit record is created when an inventory file is rejected because a key value in the file is missing.
Specifies if an audit record is created when an inventory file is rejected because the trust level is lower than the previously submitted inventory file of the asset.
Specifies if the Asset Collector raises an event when it registers an asset with the scalability server. Valid options are True and False.
Default: True
Specifies if the Asset Collector raises an event whenever the configuration values are reloaded. If set to True, a modification of the configuration values pushed down from the manager, for example, can cause the configuration values to be reloaded; in which case, the Asset Collector raises an event. Valid options are True and False.
Default: True
Specifies if the Asset Collector raises an event when it registers inventory with the scalability server. Valid options are True and False.
Default: True
Specifies if the Asset Collector raises an event when it starts monitoring collection folders. Valid options are True and False.
Default: True
Specifies if the Asset Collector raises an event when it stops monitoring collection folders. Valid options are True and False.
Default: True
Specifies if the Asset Collector raises an event when it registers a user with the scalability server. Valid options are True and False.
Default: True
