User-specific SM Installer Policy Group
The User-specific SM Installer policy group contains the following policies for the SXP logon function. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Indicates a parameter used for controlling the desktop of a target computer. It is often useful to check if the desktop is still configured correctly every time a user logs on to the system and to clean up the desktop if it does not correspond to the user's normal desktop layout. Valid values are as follows:
Activates the Desktop refresh option. The user-specific desktop is checked for consistency and modified, if necessary.
Deactivates the Desktop refresh option. The user-specific desktop is not checked for consistency.
Default: False, <locally managed>
Controls the visibility of the dialog for the logon function while the user desktop is updated. If True, the dialog is displayed, and if False, the dialog is not displayed.
Defines user-specific directories, which are exclusively checked for orphan shortcuts. Any orphan shortcut is temporarily removed.
The following restrictions apply:
Default: empty, <locally managed>
Defines user-specific directories, including subdirectories, which are exclusively checked for orphan shortcuts. Any orphan shortcut is temporarily removed.
Starts SxpLog32.exe when a user logs on, if set to True. If False, SxpLog32.exe is not started when a user logs on.
Note: Never set the value to False if you use SXP or converted MSI packages.
Default: True, <locally managed>
