Previous Topic: Shell Policy GroupNext Topic: User-specific SM Installer Policy Group
Trace Settings Policy Group
The Trace settings policy group contains the following policies for the path of the trace file. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Maximum number of backup tracefiles
Specifies the maximum number of trace backup files kept on the target system.
Default: 10, <locally managed>
Maximum number of tracefiles
Specifies the maximum number of trace files kept on the target system. This information can be retrieved using the Agents activate procedure, “SM Installer: Get latest trace” or “SM Installer: Get all traces”
Default: 5, <locally managed>
Tracefile path
Specifies the name of the trace file. The setup program defines the path.
Default: empty, <locally managed>
