The Web Services policy group lets you view or edit the following policies for web services. It contains the following policy group folder:
Non Resident Inventory
The Web Services policy group also contains the following policies. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the time in seconds to wait before initiating garbage collection.
Limits: 200–300
Default: 300
Specifies the maximum number of concurrent clients that Web Services can support.
Limits: 1–100
Default: 100
Specifies the time in seconds to wait before timing out a Web Services session.
Limits: 600–1200
Default: 1200
Indicates whether unified login is enabled for a Web Services session. Valid values are 0=False and 1=True.
Default: 0 (False)
