The Create Template dialog lets you specify how frequently you want the user to update the information.
This dialog contains the following fields:
Displays the Component Name. This could be a printer, network component, or something entirely different (for example, Borrowed Equipment or Office Materials).
Note: The component name is the group header in the template editor.
After the template has been executed, the name you have entered in this field appears under the related computer’s Inventory/Additional folder.
Describes the header components.
Schedules all the attributes that prompt the user for information.
Specifies how often you would like this information to be updated by the user.
Default: Never
The available options follow:
Displays the input box without displaying the text message. When you do not want to show any text message, select this option.
Displays the input box and the text message only the first time the template collect task is executed.
Displays the input box and the text message on the specified day of the month.
Note: The Template collect task should be enabled for that day.
Displays the input box and the text message as scheduled. You can specify the number of days after which the module should collect the information.
Displays the input box and the text message every time the template collect task is executed.
Defines the text to be shown before you prompt the user to update the information.
Opens the Template Editor where you can create a structure for your template.
