Previous Topic: Create New Template: General TabNext Topic: Create Template Dialog
Create New Template: Advanced Tab
Use the Advanced tab to specify the template file name.
Note: Typically, the default values are sufficient and need not be changed.
This tab contains the following field:
File Name
Specifies the name of the template file, where the collected template information is saved. A template file describes a component's manageable attributes in .MIF file format. This file will be present in the local asset management agent directory (typically, C:\Program Files\CA\DSM\Agent\units\00000001 or \00000003) after the asset management agent software has been executed on an agent computer.
