Previous Topic: Create Legacy Inventory ModulesNext Topic: Create New Template
Inventory Template Modules
Templates let you collect and store additional user-defined inventory information. You can either specify a value for such an inventory item or prompt the end-user to enter the value for the item. For example, you can create a new inventory item for collecting the Cubicle Number of each computer in the domain. When the asset management agent runs for the first time, you can prompt the user to enter the cubicle number and save the information.
Asset management provides a predefined template module–User Template–to collect the user, company and workstation information. By default, this module is configured for all the users in the domain. However, it does not prompt the user for information. You must modify the settings to prompt the users for the required attributes.
Note: Template inventory applies to Windows agents only.
More information:
Engines Folder
Create New Template
View or Modify Existing Inventory Templates
