The Template Editor dialog lets you add groups and attributes for the template you are creating. A group name can be asset numbers and attribute names. A group can be computer, monitor, printer, table, and chair. The values which the end user enters for these attributes are the respective asset numbers for computer, monitor, table, and so on.
This dialog contains the following fields:
Displays the Create new group dialog. Specify a name for the new group and a short description and click OK when you have completed your entry. A group is created with the given name. Click this button to create any number of groups and sub-groups.
After the template has been executed, the name you enter here appears under Inventory/Additional/Template name/group name.
Deletes an existing group. Select a group and click Delete Group. Confirm the deletion when prompted.
Opens the Edit Group dialog where you can edit the properties of the group.
Adds a new attribute to the template. Select a group in the tree structure of the left pane, to place your attribute in the appropriate group. See Create New Attribute.
Deletes an existing attribute. Select an attribute and click Delete Attribute. Confirm the deletion when prompted.
Opens the Edit Attribute window, where you can edit the information for the attribute.
