Power Up Computer: Wake-on-LAN
The Power Up Computers option lets you use Wake-on-LAN functionality to wake up, start, and control the following:
Note: For more information, see the Remote Control Administration Guide.
Important! To be able to power up a computer using Wake-on-LAN, the computer hardware must support it and Wake-on-LAN must be enabled in the computer’s BIOS settings. See the manufacturer's guidelines.
Wake-on-LAN Requirements
Wake-on-LAN-enabled Ethernet LAN adapter card
Wake-on-LAN-enabled Motherboard
Wake-on-LAN option must be enabled in the BIOS Power Management
