The DSM Explorer › Computers and Users Folder › All Computers › Computer Name Pane › Homepage Tab › Quick Launch (configuration mode) › Add an Application
Add an Application
Use the Add Application procedure to define the external application you want to add to the list of external applications.
To add an application
- Click the configure icon in the upper-right corner of the Quick Launch portlet.
The portlet switches to configuration mode.
- Click the configure icon in the upper-right corner of the External Applications area.
The Configure External Applications dialog opens.
- Click the Add button.
The Add Application dialog opens.
- Enter the name for the new application. This name is shown in the computer overview under External Applications.
- Enter the file name for the executable file for the new application. Use the Browse button to locate the executable.
Note: If you enter http:// in the file name field, the Embed View option becomes active.
- Enter the parameter for the new application.
- Select the Embed view check box to embed the web pages in the Explorer. This option is enabled only if you have specified an URL (starting http://) in the Filename field.
- Select the Supported Platforms supported by the selected application. This eliminates the possibility of an external application appearing in the overview of a computer running an operating system that is not supported.
Default: All
- Click OK.
Your changes are saved and the external application is added to the list.
- Click OK to return to the Quick Launch configuration mode.
