The DSM Explorer › Control Panel › Configuration Folder › Configuration Policy › Configuration Views Node › How to Use Configuration Views › How to Use the Common Configuration Configuration View › Configure the CSM Server
Use the CSM Server tab page to configure the CSM server.
To configure the CSM server
- Specify whether or not the agent host name is to be used for the agent address.
- Specify whether or not the agent IP address is to be used.
- Specify the hold time for messages that cannot be delivered using the Message expiration field.
- Specify the number of threads.
- Click OK.
Your server settings are saved and applied to the configuration policy.
