The DSM Explorer › Control Panel › Configuration Folder › Configuration Policy › Configuration Views Node › How to Use Configuration Views › How to Use the Common Configuration Configuration View › Configure the CSM/CCNF Agent
Use the CSM/CCNF Agent tab page to configure the common configuration agent and the CSM agent.
To configure the CSM and CCNF agents
- Specify the Delta-report interval and the Delta-report retry interval.
- Specify the Plugin check interval for task scheduling.
- Click Server-specific.
The Communication Settings dialog appears.
- Specify the Poll interval and Message expiration period.
- Click Save.
You are returned to the Common Configuration dialog.
- Click Alive messages.
The Alive Message Settings dialog appears.
- Specify values for the following policies:
- Hello interval
- Hello message retry - stage one
- Hello message retry - stage two
- Hello message retry deceleration
- Click Save.
- Click OK.
Your agent settings are saved and applied to the configuration policy.
