Previous Topic: Configure the CSM ServerNext Topic: How to Use the Logon Shield Configuration View
Configure the CSM/CCNF Manager
Use the CSM/CCNF Manager tab page to configure the common configuration manager and the CSM manager.
To configure the CSM and CCNF managers
  1. Click Job control.
    The Job Control dialog appears.
  2. Specify the values for the following policies:
  3. Click Save.
    You are returned to the Common Configuration dialog.
  4. Click Task scheduling.
    The Task Scheduling dialog appears.
  5. Specify the values for the following policies:
  6. Click Save.
  7. Click Database.
    The Database dialog appears.
  8. Specify the values for the following policies:
  9. Click Save.
  10. Click OK.
    Your manager settings are saved and applied to the configuration policy.
