Edit a Policy Using a Configuration View
As configuration views are dynamic, only the basic steps for editing policies using a configuration view are described here. Settings that are displayed in gray are unmanaged, that is, configurable on a remote computer, or have not been set.
To edit policies using any configuration view
A description of the policy appears in the Description field.
Note: For additional help with a policy, see the Configuration Parameter Nodes section of the DSM Explorer Help.
A value may be a string, number, or Boolean entry, depending on the type of parameter. A dot to the right of a field indicates the current value is the default value, that is, the value is inherited from a default policy.
Note: The Use Default Value option sets the value back to the default value, and the Make Locally Managed option lets the agent on the target system decide about these parameters.
The appropriate dialog appears.
You are returned to the main dialog of the configuration view.
The main dialog of the configuration view closes.
