The DSM Explorer › Control Panel › Configuration Folder › Configuration Policy › Configuration Policy Node (Control Panel) › Seal a Policy
Seal a Policy
A policy must be sealed before you can assign the configuration to an asset. An unsealed configuration is indicated by a computer icon with a section reference mark:
To seal a policy
- Right-click an unsealed policy in the tree view or in the Configuration Policy pane.
A context menu appears.
- Select Seal from the context menu, or click Seal in the Tasks portlet of the Configuration Policy pane.
The policy is sealed and marked with a padlock icon.
More information:
Sealed and Unsealed Policies
