Use the Recognition tab page to specify recognition parameters, or software signatures, used to identify the virtual application image when it is discovered on an agent. The asset management agent uses these parameters for discovering and monitoring virtual applications.
To specify recognition parameters automatically
A standard Browse for Folders dialog appears.
The Recognition tab page is populated with the relevant parameters.
To specify recognition parameters manually
For VMware ThinApp images, this will normally be a .dat or .exe file. If the VMware ThinApp application contains more than one file, you must enter the file name of the main data container, which is easily recognized as largest file in the set.
For Microsoft App-V (formerly SoftGrid) images, this will normally be a .sft file.
Only if a discovered image's file size falls within this range will it be recognized as this virtual application image definition.
Only if a discovered image's last modified dates and times falls within this range will it be recognized as this virtual application image definition.
Note: Each file should be entered on a separate line. Pressing the Enter key moves the cursor to the next line.
You can obtain this value from the MS App-V Sequencer. To ensure accurate signature matching, CA recommends that you specify this value.
You can obtain this value from the MS App-V Sequencer. To distinguish between versions of streamed App-V packages, the version GUID must be entered.
Note: When streaming App-V packages to clients, the package GUID is used to identify which package to download. The latest package version available at the App-V streaming server is streamed to the client. Until the App-V package has been accessed by the client, the exact version of the package that will be streamed cannot be determined. In this case, the original package version will be detected, based on the file name in the package URL. Once the package is accessed by the client for the first time, the precise package version will be detected. If the package is deleted from the App-V client cache, the version information is lost until the package is accessed again. For this reason, CA recommends that you do not fundamentally change the contents of App-V packages between minor package updates. For example, when upgrading to a completely new version of packaged software, we recommend you create a new App-V package rather than updating an existing package.
