Previous Topic: Specify Recognition InformationNext Topic: Define the Contents of the Virtual Application Image Definition
Specify Approved Licenses
Use the Approved Licenses tab page to specify approved licensing information for the virtual application image.
To specify the number of approved licenses
  1. Specify the number of approved or purchased licenses using the Approved Licenses control.
  2. Click OK.
    The virtual application image definition is added to the Virtual Applications Images node and corresponding pane.
