Previous Topic: New Software Manufacturer DialogNext Topic: Virtual Application Image Pane
Virtual Application Images Folder
The Virtual Application Images folder and corresponding pane contain all the predefined and user‑defined software definitions for virtual application images.
To create a new virtual application image definition, choose New Virtual Application Image from the folder's context menu. New virtual application image definitions can also be created when registering a virtual application image to a software delivery library.
Note: Discovered virtual application images are treated like any other discovered software and replicated from domain to enterprise. For the enterprise to be aware of a virtual application image, the custom software definition for the virtual application image must be defined at the enterprise level.
To modify a virtual application image definition, right-click on the software definition and select Properties. You can change general properties like Name, or in the case of signature-based asset scanning, you can modify the detection parameters. Discovered software inventory will be immediately updated when the virtual application image definition is changed.
To delete a virtual application image definition, right-click on the software definition and select Delete. This action only deletes the virtual application image definition and does not affect the other software definitions associated with it.
