The Add Advanced Argument dialog lets you query the asset management database fields directly. To create this type of query, you must be familiar with the asset management database, tables and field values.
Defines any text that is used as an identifier for the argument in the Query Designer dialog.
Specifies all the asset management tables that you can query. You can either select the table you want to query or select Any to query all the tables.
Note: When you select Any, you must specify the where clause manually by editing the SQL statement.
Specifies the items in the selected table.
Note: If you have selected Any in the Table field, this field is disabled.
Specifies the conditions you want to apply. You can select the macros and fields that you want to add to the condition from the Select Macro and Select Field drop-down lists.
Note: Do not begin this clause with "Where."
Specifies the date macros. You can add these macros to the Additional Where clause by clicking the Up arrow button next to this field.
Specifies the field on which you want to specify the condition.
