The File Collection table, BCKFILE, stores the configuration files information.
This table contains the following columns:
Includes the automatic increment counter used by the replication engine for comparing the values before and after the update.
Includes the Backup ID of the file.
Includes the backup definition DOMAIN ID.
Includes the date when backup file was last modified.
Includes the contents (text) of the file.
Includes the chunk number of backup file. Multiple rows are created to contain files larger than BKFILE max size.
Includes the backup version.
Default: 1
Includes the object domain UUID used for replication.
Includes the type of object.
Example: ca_discovered_hardware=1, ca_discovered_user=2.
Includes the object UUID. This column has a foreign key to either ca_discovered_hardware or ca_discovered_user depending on the object_type.
