Previous Topic: Disconnect a SessionNext Topic: Remote Control
Remove a Session
You can remove sessions from the Sessions folder at any time.
  1. Select a session under the Sessions groups.
  2. Right-click the selected session, and click Remove Session in the context menu that appears.
    The selected session is removed from the Sessions folder.
