Previous Topic: Remove a SessionNext Topic: Multiple Monitor Support
Remote Control
Remote Control permits a Windows computer running the viewer to connect to and control a remote computer running the Remote Control host. Use the Remote Control option to control a remote computer that runs on either Windows, Linux, or Mac OS X (Intel) host.
Note: Ensure that you establish a connection with the host, before you use the remote control option.
