After you attempt to make a connection with a computer, the session is placed in the My Sessions folder. This folder contains all of the computers you currently have attempted to connect to as remote control sessions, whether successful or failed, with the newest connection listed first.
Note: The Quick Connect node under My Sessions provides quick access to the Connection Settings dialog.
You view sessions either from the My Sessions tree node or the corresponding My Sessions pane. The My Sessions folder lists the name of each session, which includes the computer name, the protocol that is used, and the type of connection. The My Sessions pane lists the session name, protocol, and status.
The following menu option opens:
Disconnects all active sessions.
The session is displayed.
