Previous Topic: View a SessionNext Topic: Remove a Session
Disconnect a Session
You can disconnect an active remote control session.
  1. From the DSM Remote Control tree view, expand the Sessions folder.
  2. Right-click the computer to which you are connected and select one of the options.
  3. Click Yes.
    The computer is disconnected.
