Configure Priority for Locations Rule
You can specify the priority with which the feature selects which location rules to process. The agent evaluates the rules, and uses the specified priority to determine which rule to apply.
For example, you create two rules (Rule A and Rule B). Assume that you configure Rule A with priority 1 and Rule B with priority 2. If you configure all other parameters with the same values for Rule A and Rule B, the agent finds two matches. However, it applies Rule A because Rule A has the higher priority.
The Setting Properties dialog opens.
Highest Priority: 0
Lowest Priority: 99999
The priority of the location rule is configured.
