Configure Address Range for Locations Rule
If the agent address matches the IP Address Range criteria, the location rule is included in the selection. The location awareness feature supports both IPv4 and IPv6 addresses. When the agent matches multiple rules, the feature uses the priority value of the rules to decide which server to use.
The Setting Properties dialog opens.
Limits: The minimum value is 1 character.
If you use IPv4, you can specify the IP Address, IP wildcard, or IP Range in the address range column. For example:
If you use IPv6, you can specify the various IPv6 address prefixes in the address range column. For example:
Identifies the organization, site, subsite, and subnet.48 is the length of prefix in bits, maximum allowed number of bits is 64.
FE80::/64
Used to match a link-local prefix; that is, local subnet.
FEC0::/64
Used to match a site-local prefix.
::/0
Used to match all IPv6 addresses.
FF02::1
Used to match all nodes on the local network segment (link-local).
FF05::1
Used to match all nodes on the site network (site-local).
FF08::1
Used to match all nodes on the organization network (organization-local).
The address range to the location rule is configured.
